Ajohnson85's '87 build
ajohnson
I bought an '87 to replace my '85, with a rotting frame and tired 22re. I hate to put the '85 down, I considered options of repairing it,but this is the most logical option for me. So everything from the '85 will go in this one; front axle, suspension, the upgraded brake parts, dual cases, electrical goodies etc. etc.
'87 SR5 with a good frame. Rebuilt drivetrain; 22re, W56 5spd, top shift t-case, and 4 cyl. rear diff. And my favorite part, the red interior.
I have started taking it apart, got the t-case and rear springs out to sell to a friend, and the IFS is torched off
That's as far as I have gotten. I need to fix a couple leaks, looks like a broken front head bolt, and the rear main seal, so I'll inspect the clutch and flywheel when I dig in to fix those. I'm considering a marlin heavy duty clutch if needed, and a short shifter.
Here are the parts I have collected for the SAS and rear suspension; Sky hanger and shackle kit, TG frame plates, steering box mount, shock hoops, and rear spring hangers
And some more parts, magnaflow 11225, AFE filter for custom intake, LROR rear upper/lower shock mounts, TG diff guard and motor mount plates, and Marlin Crawler knuckle gusset kit
Hey Andy you still got the IFS stuff? Im interested in getting the arms and maybe any other spares from it. I was gonna go with a blazeland long travel for mines, and want the extra arms to build off of so my truck wont be down for too long.
Absolutely. Everything is still there and connected, you are welcome to come get it and I'll help you load it up.
The Artec Industries battery cage showed up today so I plopped it into place where I want it. I will replace the power steering cooler hose to go under the cage as the current one is in the way.
You can see the hose here
The hole in the core support for the air box, I might notch this to get the battery away from the power steering pump pulley and drop the cage down a little.
Here it is butted up to core support below said hole
It is sitting on the fender but not flat to the front, so I will need to beat the fender and/or shim the front of the cage.
No doubt. Will be a lot better than the stock j arm bracket. The artec box is well made and perfectly fit for the battery.
Looks like you are already making solid progress. Nice work! I'm really digging that red interior haha.
Low Range Off Road makes the upper and lower rear shock mounts that I am using.
I'd love to get your impression on the fit and finish after you've installed them? I used their front crossmember brace instead of going with 4xInnovation, and I wasn't impressed at all.
The upper mount is a fairly new product I'm sure, there is really no info or review on the web other than their website which states trimming for fitment will probably be necessary. A friend of mine was unable to use it for some reason I am not sure of. I suspect the proportioning valve on the frame is in the way, which I am removing anyway. I plan to add plate where it welds to the frame to reinforce it.
Are you talking about Jerret's truck? Im kinda interested to see how that upper mount works for you aswell. I was going to order it from LRO, but Jerret said theres a lot of modifying to get it to work for some reason. I have actually seen an install on it yet, so i havent pulled the trigger on it.
Yea Jerret. I have a feeling the brake proportioning valve and exhaust kept him from using it.
I looked under the valve cover today. Oil leaks out of the timing cover where it meets the head. Well, I am missing the "bolt under the oil puddle". I don't even have an oil puddle there. Does anyone know what size bolt I need?
Also need to replace the PCV valve grommet.
erinobr2000
