Ditto, solid winch. It's got me and a few others out of some tight spots.
you gonna make it out to URE saturday? planning to meat there at 9am
Post up some pics when you get the 37's mounted up, please. I just bought a set myself and need to buy new leaf springs, I'm wondering how the clearance will be for you with the 4" TG springs and the 37/12.5's?
I sure will, and yes they are 12.5. I ordered the wheels from Summit lastnight. Same ones I have now, Pro Comp 52 with 2.5" backspacing but in 17" flavor. I am currently running 1" spacers because the inside of the 15" hits the top of the caliper without them. I will probably remove the spacers and shave the calipers so the backside of the wheel won't hit, and hopefully reduce the scrub radius enough to keep the tire off the firewall. We will see.
Are you going to have them externally balanced? I've been reading about using air soft bb's to internally balance large tires and might give that a try.
grab a can or two of starter fluid you'll have the beads seated in no time:thumb:
Yup thats what I'm debating. I just wondered if that will destroy the airsoft bb's inside the tire though :shrug:
you would put the balance beads in through the valve stem after you've "starter fluid mounted" them lol
and the trick to it is spray the fluid around the inside of the tire then spray a trail of fluid a couple feet away from the tire then light the trail of fluid. It works all the time on the trail. have a towel or something handy to pat out any fire that continues to burn. Also make sure the valve stem is in when you do it other wise you turn your valve stem into a mini torch lol. The idea is that when the tire seals it cuts off oxygen to the flames.
