Alarm- Door Pin Question
saweetlou
I just installed a aftermarket alarm in my 99 Ltd and im having a hard time finding a wire to to tap into so that all the doors will trigger the alarm. I normaly just tap into the dirvers door pin switch but for some reason it only works the drivers door I then read somewhere to tap onto the key ring light and again it only does the drivers door. According to most wireing diagrams it says to go to the drivers side juction block, is it behind the fuse box, is it safe to use cause every other thread talks about having to replace it. Is there somewhere else i could tap into.
There are two option that I know of:
Grab the signal at the drivers side pin and run a wire from the passengers side pin and T them together using diodes to isolate the signals so you don't screw up the factory system.
or
What I did was grab the wire at the gauge cluster from the door open light. I don't remember right off what wire it was but if you grab the factory service manual it should be easy to find.
2001ATL
