Alignment advice for leveling kit
bruinjay
Hey all,
I'm getting the front end of my '14 trail leveled with rear. 265/70/17 with stick uca's. Would you recommend I have alignment shop max out + caster or not necessary/needed with mild front lift? Thanks
Anytime you alter front end suspension settings you need to get an alignment performed. Hence you can see what they can achieve with the stock UCA's first and decide if that is your choice. On my FJ I went ahead and had the new UCA's installed at the time of lift as I wanted to ensure I could get a good alignment since I do a good bit of interstate driving at 80 mph.
TerryNap61
