Alignment Recommendations in New England (NYC-CT-BOS-Cape Cod)
hockeydude2k
Hi all- I'm pretty new to the forums so thanks in advance for everyone's help.
Does anyone have any recommendations for a good place to get an alignment after a lift anywhere in between Boston, NYC, and Cape Cod?
I am doing the Tundra/LC combo documented by Rickashay, which IMHO is a pretty decent lift so I want to get it done fairly quickly once the lift goes on.
Before pics below. After pic to follow.
That's a large area.. if you're planning to install that lift in NYC, I keep hearing good things about a place called the Custom Shop in Astoria. Never been to, just heard of. Give a call and see if they do alignments. If you're installing the lift in Boston then you will likely ruin the tires once your reach any shop in NYC. If your vehicle has been exposed to salt, then do not expect a proper alignment without new LCAs and camber bolts.
DJNutshell
