All I want to do is get the front level. What would be the best spacer to use?
and I'd say you need your eyes checked. A (physically) 1" thick spacer gives a perfect amount of lift. I'd say yours wasn't really that small of a lift. Honestly, for a total of $60 for the lift and alignment it was worth the money!
Sorry, but I've measured mine both before and after. The spacer was exactly 1/2" thick and the amount of lift it gave me (as measured from the flat part of the wheel wells to the ground) is exactly 1". I'm not so sure why that's so hard for you to understand.
BTW, my lift didn't require an alignment. It was still within factory specifications.
and I'm not sure why you can't read the measurements and know mine isn't over-leveled. I also know the spacer was exactly 1" thick. either way I'm happy with what I got and I got a great price on it. I'd recommend it to anyone. I'd also recommend having the alignment check afterward even if someone says it will be on... mine was way off with my lift.
there's a lot of honduh boards you can troll too
DocMT you have got to be the most transparent and narrow minded person here. You are so clueless it is just sad, you clearly do not understand measurements and as proven in this thread you also fail at the English language. You do realize that there are other cars in the world than YOUR 4runner right?
You have from what I have read, installed 1 pair of 1/2" spacers in all your years, so I am not surprise you think the way you do, enjoy those rose colored glasses!!:lmao:
There are literally HUNDREDS of threads where members here got twice the amount of lift as the thickness of their spacers. In fact, read this thread and you'll see that EVERYBODY who posted pics in this thread also got a 2:1 ratio of lift from their spacers. Somehow it is ONLY YOU who claims otherwise.
So it looks like YOU are the most transparent and narrow-minded person here. Please don't talk to me about the English language when your grammar is inferior to mine. Have a nice day.
I already told you that I don't care what you did to your 4Runner. It just doesn't matter to me. If you're happy with it, then that should be good enough for you.
Do you own a Honda? Do you troll there too?
is this what you guys are arguing about?
**The lift spacer is NOT a 1:1 ratio - Meaning that the lift height achieved is much greater than the actual thickness of the spacer. The reason is that the lower control arm compounds the amount of lift due to its angle and length.taken from here
2003-2011 Toyota 4Runner 2" Leveling Lift Kit 2WD 4WD | eBay
so if I read that correctly, a 1" thick spacer will achieve more than a 1" lift....and a 2" thick spacer will achieve more than a 2" lift....
i.e. 1" thick spacer = 2" lift respectively
2" thick spacer = 4" lift respectively
Yup, that's pretty much what everyone here already knows. It's a 2:1 ratio of spacer thickness to lift.
Interesting... That is good info
correct - I installed the Daystar 2.5/1.5 this weekend. The front spacer measured 1.5" in thickness. It raise the front of my car 3"
youngrk
