Amateur Radios
Is that a flexi antenna or rigid? I used to roll with a diamond, but because it was rigid, I always had to lay it down before going into parking garages.
I'm running an Icom IC-2730A with NMO hood lip antenna mounts and I have a Baofeng UV-82 rattling around in the door pocket if needed
Sorry to revive this 1 year later, but I came across it and wanted to know how you mounted/secured your 2730A to the lower center dash pocket?
It's just the faceplate. I made aluminum brackets that are HD velcro'd to the bottom of that cubby. I did Velcro because I wasn't sure if I would like that location.
If you are constantly fiddling with your radio it's a little tough to see, but if not the location works well
Sent from my SM-G930V using Tapatalk
