amp bypass anyone installed metra70-8117
eric4runner
has anyone installed this does it make it so you can just run the speakers off the aftermarket deck anyone have a write up of the install ???
Could you be more specific? Which system is it for? I'm going to assume its for the JBL system.
yeah to the jbl 10 speaker system i have a 03 4runner limited I really dont care if all 10 speakers work. I installed the scoshe kit to power the stock jbl on but it seems like it fades in and out on songs mainly fast paced rock so i wanted more direct to the alpine headunit any input would be good thanks
i cant remember what exactly the part number is, but yes its 100% easy and possible to run the JBL system with an aftermarket deck...
Has anybody used the Metra 70-8117. I plan on bypassing the factory amp and installing a 5channel. For now I still will use the factory mids and highs, might go ahead and replace the sub.
1) Is there a way to still use the factory center dash speaker?
2) The front and rear tweeters are they on a sperate channel or are they tied in the same channel and the front and rear?
3) Anything else I need to know when using this harness? Or is it really just plug and play?
