Amp Locations for a 3rd Gen?
Can't do photo at the moment, but under the driver's seat is a great location, followed by the passengers side if you have a small amp, as the rear heater gets in the way. If you have a cool running amp (class D usually) you can place it under the rear seats.
I haven't really checked yet but I know I have heated seats and from the front not much room under there. It is a Class D Alpine MRP-M500.
I have my 5 channal amp mounted under my drivers seat as well. I think it's one of the best spots personally.
I have mine mounted on the rear of the rear seat. just make sure than they are in there good otherwise they will pull out. i'll see if I can post up some image but you get the idea.
Not the greatest pic, but should give you an idea that you should have plenty of room. This is a JVC 800w
The alpine should fit fine, I had a 4 channel alpine pdx that was the same basic size under the passengers seat.
Here is mine no trimming required! :D Wires can be run more cleanly, but other than that this works out great!
Is that a 10" Sub? How does it sound?
I am picking up a 3 month old set up from a friend. Alpine MRP-M500 with an Alpine Type R sub in a 1 cu. ft. box for $185.
txbonds,
Like the setup. Def. post pics of it once it is installed.
txbonds,
It is a 12", but yea it sounds great perfect addition to the factory sound system.
According to the Alpine interwebz page:
RMS Power (at 14.4V THD+N, 20-200Hz)
Per channel into 4 ohms: 300W x 1 (0.08% THD)
Per channel into 2 ohms: 500W x 1
Giguchan asked me to post these in case anyone else wanted to see
Clocktower07
