Amp Mounting pics, and wiring locations.
kdawg532
I'd like to see some pics or here some Ideas of how you ran your wires for an aftermarket audio amp in a 2nd gen t4r, as well as mounting locations, just so I can get an Idea of where I'd like to put mine, as I really can not decide where to put mine :confused: Any help would be very much appreciated.
I put them under the front seats. One for the rear and one for the front. Ran all the cables under the door sills and carpet. I think it took more time getting at the back little tweeters by the rear window than anything.
If you are replacing the speakers too, make sure they fit perfectly without gaps. As this will kill all your bass and mids.
If you put a box style sub in, mount the amp to the side of the box. Also use XLR connectors to the sub for easy removal in case of needing all the cargo area.
Hmm, I like the Idea of putting the amp under the front seats... It would def make it a lot easier for wire running....... The last time I had to run wires I did it in a pick up, which is a lot easier to hide and run. I like this idea.
