Metric sockets from 10mm to 21mm. Or maybe 22 or 23mm. I forget. Def at least 21mm.
Torque wrench.
Metric combo wrenches, especially the 14mm IIRC for the inboard upper shock nut.
Wire or zip ties to hold caliper. Wires and brake lines must not be stretched.
Good quality, tall-enough jack stands.
Anti-seize.
Be advised that your jack needs to be 2.5" higher when the job is done.
Careful when manipulating the sway bar. Squeeze the rubber boots on the sway bar links at all and the grease will come out. If I were to do it over again, I would remove the skid plate first, remove the sway bar mounts, disconnect the sway bar links from the spindles, and rotate the assembly up and forward, out of the way. Then carry on with the rest.
Make sure your jack is tall enough. My full-size craftsman floor jack almost is not.
ETA you will also need a BFH to break the upper spindle joint loose. I have a 3-lb. copper hammer and it did take a few whacks.
