Another lift question
rok medic
If I run 2.5"billet spacer like procomp or daystar or something up front , do I need a rear spacer lift and diff drop ? Also should i go with the 3" up front or will that cause issues ?
If you go 3 in the front and nothing in the back, your front end will be higher than the rear and look like you're hauling rocks in the back. Plenty of lift & level kits w/ diff drops on the toytec site with varying price ranges.
Already run ko2s 15 limited
new wheel and tires are 6lbs lighter than stock 20s
How much rake do you currently have? If you measure less than 2.5" it'll be reverse rake without lifting rear. I don't remember whether stock is 2 or 2.5". Also toytec recommends against doing more than 2.5" with xreas, look at their spacer lift.
So had someone tell me at supreme suspensions that you can't lift the xreas at all/ daystar said its no problem anyone have any ideas really want a billet thats just a strut top spacer no disassembly of the strut .
I called these guys, they said you can't lift an xreas at all. Although they say it will on there website but also says you need a compressor to install but other company's-like daystar , toy tech say you can . I guess I'm wondering if this kit would work didn't look different than the others ?
Ok so I just order the motofab billet 2.5 " spacers that I have seen in stores for $200 there on sale on eBay for $37 and $20 diff drop and skid kit ,so we'll see how well my $57 budget lift goes will post pics after I install it . It measure at 19.5 " up front and 22 "even on both rear tires so it should be level probably going to grab a set of the 1" poly spacers on Amazon for $30 for the rear
Since I'm traveling the country I sold my house put all tools in storage 2000miles away so any you guys know what tools I need to borrow or live near twin falls area
Metric sockets from 10mm to 21mm. Or maybe 22 or 23mm. I forget. Def at least 21mm.
Torque wrench.
Metric combo wrenches, especially the 14mm IIRC for the inboard upper shock nut.
Wire or zip ties to hold caliper. Wires and brake lines must not be stretched.
Good quality, tall-enough jack stands.
Anti-seize.
Be advised that your jack needs to be 2.5" higher when the job is done.
Careful when manipulating the sway bar. Squeeze the rubber boots on the sway bar links at all and the grease will come out. If I were to do it over again, I would remove the skid plate first, remove the sway bar mounts, disconnect the sway bar links from the spindles, and rotate the assembly up and forward, out of the way. Then carry on with the rest.
Make sure your jack is tall enough. My full-size craftsman floor jack almost is not.
ETA you will also need a BFH to break the upper spindle joint loose. I have a 3-lb. copper hammer and it did take a few whacks.
Last question would I be better off going with the 2" or should I be ok with the 2.5" also am I going to have to run a rear spacer either way ? Or should the 2.5 " be ok without ? My measurements are 34"f/36.5"r driver side and 34.5"f / 37" r passenger side
I went with 2" because I didn't see the point of a lift that requires a diff drop and didn't want to stress my CV joints.
That left my rear 0.5" low which I took care of with air bags.
Now it is even and I can air up as needed to keep it that way.
