thorridder
im looking at taking this think in another direction. wondering of just the bottom hinge is enough to hold the 35" tires and possibly more.
I would say it could be, but the frame that holds the tire would have to be a different design than the picture shown. Maybe more of a triangle configuration with the tire in the center.
Might be good to have some sort of attachment point right around the back of the tire to keep the tire from vibrating too much.
this
if i got a pic of my truck and where it goes i could show better, with multiple pics, its at an angle coming off the plate right under the frame. kinda hard to describe
yes it is possible look at CBI and ADO they both use a single hinge point, most of the failures have happened because people only top mount/weld the hinge to the bumper, but if you use a through pin that is welded at both the top and the bottom of the bumper you will increase its strength. also if you can tilt the tire so its not vertical that helps as it "pushes" the weight into/onto the latching mechanism to help support the weight as well. another thing to think about is the placement of the tire, the further away from the hinge you place the tire the more stress it puts on the hinge, -the longer the arm the greater the leverage which means greater mechanical advantage, and a greater chance of failure. i hope all that made sense
i wouldnt use this platform at all, id make something custom. that tubing that carrier is made out of is not strong enough to work with just one mount it will fail. it was designed with and needs two mounts
yea yeah i get what your saying. it will be where the latch holds it some, but im more worried about when it is all the way out. and its big pipe for sure but its also a big tire. we thought about keeping the top hinge and running a pin though top and bottom but it would go right over the light.
Why are you considering a single hinge design instead of normal retrofit? What's the advantage?
I agree 100%
I think the problem lies in that it is a 2nd Gen tire carrier....and he's having issues modding it for his 3rd Gen.....
Not sure why you can't access the bottom hinge area...will have to look at mine...but Blcktpgsr put his 3rd Gen carrier mount under the light...so it should be doable.....
