Antenna Mast Replacement...Help, I really did it now...
aznguile972
I was in the process of removing the antenna mast and found out that the mast had broken. So, I had to remove the tire wall and get to the antenna motor. Tearing up the tire wall, I finally get to the motor. I unscrew the bolts holding them together and somehow can't seem to the 2 halves to come apart. I figure I need to unscrew the screws holding the metal relay-looking thing. This is where I screwed up. I decide to pull on the relay-looking thingy and everything comes apart. I tried my best to put it back together and put everything back in. I go to turn on the stereo and see if my antenna motors turns. The light on the stereo flickers and goes out. No sound came from the antenna motor. Now, I have no idea what to do.
I am having problems with my power antenna and would be interested in the answer you get. I think I am going to do the Tacoma whip mod that is listed here in the Forums, then you don't have to worry about the antenna motor having to work as the Tacoma whip antenna is not motorized.
If you need to get another motor I saw one listed on eBay that ends in about 24 hours, it is currently less than $15.00, search eBay using "toyota 4runner power antenna" and you will see the 'stock' used antenna motor for 3rd gen 4runners.
Also if you are interested in the Tacoma whip mod search here with "Tacoma whip mod" and you will find a good posting. Good luck.
Personally, I'd prefer just to have a diversity antenna like most other cars. I'm not sure what happened here, but I'm hoping that by me trying to fix the motor, I didn't burn out my stereo. I hope it's just a fuse.
3rd gens have a diversity antenna.. its in the pass. side rear window.
Whats a "Diversity Antenna"?, My antenna wouldnt go up or down but the motor would still run everytime I started or stopped the engine so I just disconnected the motor and left the antenna up. Dealership wanted $230.00 to fix it.
The antenna is connected to a plastic strip with teeth on it that feeds into the motor, yours broke thats why the antenna will not go up or down.
See the writeup I did and you will see where I take it apart to get the broke strip out.
$230 they should be shot:awais:
Mike
I got an aftermarket antenna on eBay from antenna-x or something like that. It came with really crappy instructions and it only sort of works. When I initiate the FM/AM function of the radio, the antenna goes up, as it should, and then immediately retracts after about 2-4 seconds of being fully extended. When it finally goes all the way down, it remains down until you switch the cd and switch back to the radio.
I dunno, I think I'm just gonna get a whip antenna. This power antenna doesn't seem worth the hassle.
I have a 1997 Limited with the wide trim fenders. I received the new antenna mast in the mail off ebay today and I'm trying to take off the fender wall cover to access the motor and remove the broken cable. How????:confused:
I've searched all over and have only found examples of people doing this on the SR5's with the plain fenders.
I took out all the screws that I could find and pulled while still trying to be careful and not screw anything up. I couldnt figure out how it's supposed to come off. Can anybody help me out?
Ryan
anybody?:(
i'm a broke college student and cant afford to pay somebody to do it for me right now.
i MUST figure out how to get that fender open...:p
Just unscrew the top nut on the antenna, and turn the radio on. This will force the cable out. Then, put the new mast in, and turn the radio off, and in goes the new cable and mast. Put the top nut on, and youre in business.
Thanks for the reply.
I've gotten that far, I've already taken the old antenna out and the plastic cable is broken off about 2/3 of the way down so I have to access the motor and get the old portion of cable out before I can install the new one.
I read where you are supposed to take out a few screws on the inside of the fender and pull the cover back to access the motor, but on the Limited version the fenders appear to be different. This is where I'm getting stuck. I'm not sure what is the correct way to take them off so i can get to the motor?
Inner fender well
Hey man, not sure if you figured it out yet, but I had to do the same thing, and I finally got to mine. Yes, undo the screws. What I'm guessing you're seeing now is a plastic round "head" looking thing where the bolt/screw came out? Just pull the fender well off of that. It's a little scary, but the fender well won't break. That plastic thing is a little plug that inserts through the fender well, into a square hole. It has two "legs" which lock it into place.
I didn't pull the fender well completely off, just the back rear section (nearest passenger door). Once you get the fender well pulled off, the little plastic plugs are more easily gotten to, you can maybe remove them and reuse them. If not, rip them out and buy new ones. It cost me $2 for 4 of them. I think they are easier to deal with in warmer weather, it was very cold the day I did it and the legs would not depress well, I could only save one of them.
I took some pictures of what mine look like. Along the outside of the fender well, there were bolts which held the fender trim piece on. On the inside (nearest the motor), the same plugs were there, just no bolts going into them. I shot a picture of one on the inside of the well.
There is also a picture of the fender well, with the square hole. It has square holes at each one of these plug locations. Also is a picture of the little plug.
Again, remove the bolts and pull the fender well off.... it'll pop off the head of the plug. Do this to enough places to access the motor. Remove the plugs by squeezing the two little legs together, and pull it out of the hole. It takes 11 or so if you wanna replace all of them, buy them first maybe? That way, you can look at what you're working with (and was what I did).
Do what you have to with the antenna motor, then line the fender well back up with the holes. Push the plugs back through the fender well into the metal retention spots. Drive your bolts back through and you're done !!
The Toyota part number for the plugs is; 90189-06028. They call it a "screw grommet". My dealership only had 4, I could have used another 2, will have to get them later.
Good luck !!
I have come to live with my issue for the past month or so. I'm still having problems with my antenna motor as described in the first post. Thank goodness that it did not blow anything but a fuse. Every time I switch from CD to radio, it blows out the fuse. Seems like I need a new antenna motor.
Anyone switching to a whip antenna wanna sell me their "working" antenna motor?
Oh and BTW, thanks ChopperDude for your informative post. I really needed help with that because my fender well is not attached like it should be. I'm afraid some water might get in between the cracks. The part number is going to help a lot.
I wish I had read your post before I started the antenna replacement. I found yours after I'd finished. I looked for something about 2002 4RS but I didn't look well enough I guess. Good comprehensive description. As you state, the process is a little more complicated than the easy squeezy version posted elsewhere. I removed the wheel and finally figured out how to remove enough fasteners to peel back the well liner to access the motor. I only destroyed one fastener.
I don't know why anyone would fuss with the power antenna. Mine started going up and down randomly when driving so I replaced it with a 13'' rubber type one from Wal-Mart online for $7. Works great, looks good and no more worrying about it. Pics are in my garage if you want to see what it looks like.
But yeah, once the power one breaks I would say screw it and go with a universal or even better the Taco Whip Mod.
BillM777
