Any Car Alarm Guru's out there?
la79
Hello, so I have a 96 4runner with an aftermarket alarm system. It's a DEI Rattler 300.
Recently I changed the battery as the car was having a hard time starting up. After I changed the battery I ran into some issues. The car would still not start very well, so I took it in to have the starter and alternator checked. They all checked out great.
However tech noticed that the car will not start with the door closed. The weird thing is if you open any door the car will start. Also, the funny thing is when I turn on my headlights the alarm system chirps randomly and goes off.
I also noticed that the "brain" to the alarm system makes a clicking noise every so often. The key fob does not arm or disarm the vehicle either and does nothing. I finally removed power to the alarm system but the problems still persists.
Anyone out there who would know anything about these type of alarms? Is it salvageable or should I just remove it and put everything back together?
Appreciate your advice.
Yes alarm module can be reset by battery disconnecting. I have similar problem with my remote starter after battery disconnecting it start working improperly ( starting engine and then after 5sec. turn it off). In my case I don't know brand of module and I don't have any fob for RS module (it remote start by pressing 3 times close button on my oem fob).
You should try reprogram Yours system ( see link on previous post)
Well took everyone's advice. Also ended up checking and double checking all wires. Still no luck. So I removed it. Alarm lasted 16 years on my rig. Got it installed at Circuit City when it still existed for those of you who know about them!
Thanks everyone!
2001ATL
