Any DIY water pump threads for a V6 4th Gen?
trey99ek
I've searched around and I see a bunch of treads on 3rd gen water pump replacements and 4th gen v8 replacements, but nothing on a 4th gen v6. I am sure it is pretty similarly but I am curious. I keep seeing threads on "is my pump good" and I am going to drain and fill the coolant and replace the serpentine belt, figured I may as well do the pump while I'm at it. Any lead on this wound be appreciated.
Thanks. I wold have never though to check over there. I rarely go there.
Just did this again following this thread because I originally bought a POS Gates Water Pump:bash:. Only by Aisin and follow ths thread and it will be a snap.
No, I only replaced the pump and gaskets and changed all the coolant. I go by if it ain't broke don't fix it.
I used to go by this until I did a water pump on one of my old vehicles... everything was great until the tensioner pulley fell apart on me a month later with no warning.
$60 worth of parts can save you a lot of time and headaches down the road.
The tensioner is behind the alternator, not the water pump. The only benefit of doing it with this is if you're replacing the radiator too. Gives you a lot more room to deal with the alternators bolts that will be stuck!
You just made me take a look at the write up for the v6 4runner. I'm honestly really happy I did, I'm used to water pumps being part of the timing belt, I'm way less worried when mine goes now. :reddance:
For anyone needing a step-by-step for replacing the water pump:
TRQ/1A Auto has many other excellent videos on various 4th Gen repairs. I'm not affiliated with them in any way, just sharing since their videos have been so helpful.
alexaturner
