TRZ06 said:So, all I need to know is my bulb type and I am good?
What is the price range for these kits?
The Lexus GX forums seem to like XeonDepot
I'm going to Silverstar my highbeams and fog lamps, and HID my low beams
iFORCE said:The silverstar route was what I did.
If you are not going to put a real hid kit in.. meaning the clips and stuff... go for the rebased ones. Most of them will be that anyways. rebased just means that its the HID bulbs with a 9006 base so you don't have to modify anything else.
My ballast + bulbs = Denso/Philips (Toyota/Lexus factory)
xenondepot = popular.
TRZ06 said:Ok, you lost me. What is a "real" HID kit? I am buying the 4300K HID kit from Xenondepot.com. Is that considered a "real" HID kit?
It is the H11 HID kit, which is the type of bulb the projector lamps uses. They are not a rebased kit to 9006, but an H11 Kit
What are theses clips you speak?
TRZ06 said:Oh ok, then I guess I am getting rebased HIDS.
The stock low-beam bulb in the 06's is the H11. That is what the projector lamps use. I got that info. from my owners manual.
So I am getting the H11 HID kit.
I am assuming a dealer would not install these. Know anybody in the Bay Area, CA that could install for me?
iFORCE said:in regards to install... its very simple. There is only one way to connect everything and the bulbs install like any other halogen bulb. The ballast is something that takes the most time.. and that's like 5 minutes. The ballast (square-ish metal box) needs to be secured in the engine bay. This can be done with screws... a homemde metal bracket... or I don't know but there MIGHT be a place for you to screw it in on the bottom of the headlights itself. That all sounds confusing.. but its not.
remember... bulbs go in like regular bulbs and secure the ballast so it doesn't move.
btw: once you get it going... when you turn it on.. it'll make a buzzing sound. quite normal as the ballast is working and your bulbs should magically light up. Remember... you're working with lots of electricity!
do you have a link to the product that you're getting? I jsut wanted to take a look.
TRZ06 said:Is this buzzing sound heard from inside the vehicle, and does it go away right after the lights fire up? My Audi didn't make any noise when turning them on.
TRZ06 said:I just realized that the link that you wanted was the HID link, and not the link to my other mods.
DAHHHH!!!
Here is the HID link
www.xenondepot.com/product.php?product_id=5
iFORCE said:with that one.. you'll need actual HID headlights with the metal clips. The metal clips hold the bulb in whereas your halogen ones are held in by tabs.
you will need THIS instead of the ones you showed me. These will fit in your headlight with NO modifications.
4RunnerRon said:After much research, I chose XenonDepot for the HIDs on my 06. I have been happy so far and I think most others have been, as well. Do a search and you'll find my post on review and install of my kit. (my previous user name was T4Runner06). Good luck.
