Any lifted 4Runners with stock tire size?
They’d be LT.
I think the doorjab for LT tires (gotta get the dealer to replace the current P-rated jab) says 44psi. Depending on load, I run mine between 38-40psi. On trails without much technical parts, I run them at about 24psi. On technical trails, I like starting at 16-18psi.
They’d be LT.
LT you have to play with the pressure a little more, but you should be running higher pressures to achieve the same load rating. I run my load range C LT tires between 40-46 psi cold depending on my load. Around town 42 psi seem to be about right by chalk test with what I carry in the back on a daily basis.
5100's at 2.5" with stock springs in front, T13's in the rear, 265/70/17 tires.
Before and after.
265/70 R17 Falken Wildpeaks
Dobinsons lift 2.5” front and 1.65” rear.
2.5" Toytec superflex springs in the rear with Bilstein shocks, 1.5" I think cornfed spacer in the front. Stock size Nitto Terragrapplers
Thank you for sharing. I'm currently waiting on my rims to come in and so I figured there would be a chance I'd end up doing a 3in lift beforehand. I've had to visualize what it would look like but this makes it easier. Lol I feel relieved I'm not losing my mind now. Ttyl
Here's my before and after picture. Mods are in my signature - 6112s set at 5th clip both sides.
I am in the process of considering this same exact setup for my 2022 TRD Off Road Premium. My only debate is whether to go with the 275/70r17 or jump up to 285/70r17 like you did. Any rubbing with this lift at these settings and any noticeable power loss from the larger tires?
ZukeMan26
