Any mod suggestions?
Welcome! My first mod was removing the running boards to make it look a little higher off the ground. And then I bought the daystar kit for a 2.5/1.5 lift. I'm still running that setup right now.
edit: just saw that your running boards are already off, nice!
Hey I'm getting a roof rack which I think will look cool I just would like to know do you think it would look weird to tint the front turning lights yellow??
Skip the factory roof rack, they're weak and u gotta drill holes. It looks cleaner without it. Besides EVERYONE has one. Yours doesn't. If u are dead set on a roof rack(how often are u gonna use it really?) then get a Thule or Yakima. Much cooler looking and more versatile.
For bikes a hitch mount rack is best. Easy bike load on/off, easy remove/install, bikes don't get creamed when you forget and drive into a garage, lower wind resistance than roof rack. I just throw my skis in the back. You can find second hand racks on CL. Use REI website for fit info.
Do they make bull bars (push bars?) for yours? Look kinda tough and have practical value of fending off contact from other vehicles, i.e. not just a poser accessory. Not as heavy or expensive as full bore off road all steel winch ready custom bumpers. Plus, it gives you a place to mount a couple of auxiliary (led) lights.
A cb radio. Super practical. Not expensive. Easily done by you for $200-300. I have the uniden 520xl. Small with good performance. Trucker talk Helps keep you informed of radar traps and general enforcement vehicle locations, and you get to mount a sweet auxiliary antenna on your vehicle. Lots of threads about antenna brands, styles, and mounting suggestions. And most have PA output. You can install a loudspeaker under the hood/behind the grill. That's good times, a secret loudspeaker. Good times.
I have a bike rack and ill get a Thule for skis and stuff
Maintenance
I say do all the needed maintenance and go from there,getting it in tip top shape is better than rig full of mods that you will never use.your young and have plenty of time and money to be spent on this rig .Good luck on your new TOY.
BillM777
