Any pics of just FJ springs and shocks installed?
You can combine the Toytec 1" (net lift) spacer and that 1/4" spacer, but after speaking with a Toytec rep this isn't an advised setup. The Daystar is listed as 1", but it gives more like 1.75-2" of lift. If you want more than the Toytec, go with the Daystar. The Cornfed to my knowledge does give the true 1". I've got front FJ spings with the Toytec spacer, and it's pretty level, but a little rake left (higher in the rear). With FJ springs front/rear, combined with the front spacer, there would be even more rake than I have. You have to remember, the FJ springs are stiffer and there is less sag when towing, so it's not as big of an issue as before with stock springs.
Hey Thanks for the pic GATOROSE ! I think that looks perfect with the 1/4 spacer. Still has some rake for towing and the boards are not pointing the wrong way.
Thanks again
Bruce
Anybody install a set of 2010 FJ springs on a 4th Gen yet? I found a cheap set and wanted to know if they're identical to the 07-09 springs.
Thanks again
Bruce
No problem, thanks for the compliment!!! I haven't seen anyone else do the 1/4" and everyone said I should to go bigger but I love it, just a little rake and its hard to tell the running boards aren't level.. The new ride quality is the best part though, no more boating over bumps or around turns!
I don't remember which person did it but the 2010 FJ springs were installed in a 4th gen 4Runner with good results. The lift/drive improvement was in line with what everyone else has reported.
275/70/17 BFG AT KO
Toytec 1 inch spacer
8k miles FJ Springs
