Any way to add a 120VAC outlet inside the center console or dash?
RobS10
Member
I see earlier 5th Gens had a 120VAC outlet inside the center console...brilliant, Toyota! But sadly, Toyota decided to remove it in a refresh. Any way to add one back, or somewhere in-dash? I occasionally need to charge my razor and using a cigarette lighter inverter is a PITA.
I had a 5th gen Tacoma with an outlet in the bed and there were write-ups on adding an outlet because the inverter was underneath the center console.
Still waiting to take receipt of my 4runner so I don't know if that's an option on the 5th gen 'Runner, but sharing as a data point in case you'd like to investigate.
There used to be two, one in the center console and one in the back. Now there is only the one in the back, so maybe there is a way to tap into the existing inverter, since the model hasn't changed that much. Hope there is an easy retrofit.
charlesz
