anybody running AllPro 3.5" coils...help me out
DMC91187
what shocks did you use for the rear? a buddy of mine said he used Tacoma BLS 5100's because they are a bit longer and wont bottom out but he had to press in new bushings ...im just looking to hear some other options...also has any1 ran medium duty coils in the front without a bumper ( until they got a bumper ) i know people say it will make the truck ride real stiff....but then i think if i threw 120lbs in the truck ive never noticed a major difference in the ride
From what I understand, Looks like the valving is different for the 10-13 vs. 07-09 5100 front shocks. Rears I know have different diameter mounting eyelet for 10-13 rear shocks , see below for details on fronts.
I'm running the all pro rear springs with Radflo's 2.5 extended travel rear shocks. The valving on the shocks is right in tune with the spring rate. Provides a great ride even without extra weight, yet still allows me to carry extra weight.
I ran an OME heavy duty front strut setup that was rated for an additional 200 pounds on the front of the truck and it ran rather stiff with the sway bar on and no bumper. I removed the sway bar and the driveability came way back into proportion. I've switch over to adjustable coil-overs from radflo since then to match the rear. So I wouldnt worry much about jumping into a medium duty strut for the front without a bumper.
so once you switched over to adjustable coil overs did you hook the sway bar back up or leave leave it off?...how much height would you say you got total out of your set up?...what size tires are you running?....Right now i have the toytec 3/2 spacer and im running 285s with 1.25" spacers in the front and I rub slightly, its livable but thats why im considering going up a little more. anything special that im missing that you had to do or recommend doing with this set-up?
No, the sway bar is still removed for additional flex off-road
From ground to bottom of fender lip I'm sitting:
Front: 41 3/4" left and right
Rear: 42" left and right
305/70/R16 mickey thompson baja MTZ's (33x12.50)
this is my current setup (just copied and pasted from my build thread) I would recommend out of the following list to definitely get the adjustable upper control arms if you don't have them, as well as the extended rear sway bar links. you can get these from medic83 or phil from toyota120.com or fab shops like metaltech, wabfab off-road, and perhaps a few other places. medic83 on the 120 forum seems to have the best price. You will also want to extend the rear brake lines or atleast make a drop down bracket to lower the brake line mount where the brake lines in the rear switch from hard tubing to flexible hose. The diff drop kit isn't necessary; however, it does reduce the wear of the cv axles by a small percentage. plus it's 40 bucks so i said what the hell it can't hurt lol. hope this helps
Suspension/ wheels mods/additions:
-Radflo 2.5 extended travel 650lb spring adjustable coilovers
-Overland warehouse 2.5 rear extended travel kit (minus coils)
-All pro 3.5in lift rear springs w/ daystar 1.5in rear spacer on driver side coil (driver lean eliminated)
-restuded front hub (1/4" longer studs for 1/4" wheel spacer)
-1/4" wheel spacer plate (to remove wheel/brake caliper interference)
-Black rock D-window 16"x8" rims with 4.25 BS (wheeL back spacing + 1/4" wheel spacers equals 1" wheel spacer on stock wheels)
-Mickey Thompson MTZ's 305/70/R16 tires
-SPC performance LR UCA's caster set at -3 degrees
-front sway bar removed
-Medic extended rear sway bar links (from toyota120)
-Roger brown 1.25inch body lift
-body mount chop
Engine/ drive train additions/mods:
-VSC system cut off
-internal snorkel mod
-k&n air filter (factory box)
-HFC delete
-Resonator Delete
-toyteclift diff-drop kit
-4.56 gear ring an pinion front an rear
-ARB front/rear air locker(s)!
-lucas 85w-140 gear oil
lol yea right after I replied I was like:brick: he's probably got a build thread you could look at...annnd you do....a sweet 1! Anyways thanks for the help man I appreciate it! I'm gonna use your truck for inspiration lol
Jhunt
