Anyone have a camping/sleeping setup inside of the 4Runner?
just finished mine last week. Airbedz P303 - little snug bug fits well :bravo:
i was fearing the hump would be an issue... imo its not. Didnt even feel it.
My issue now is the ceiling hooks and getting those to be more useful with hanging stuff off them... Thinking of swapping out the bolts for eye bolts...
Do it! 5 minute swap. I did on my 4th and 5th gen and use them frequently. You can swap out the plastic trim panel bolts for d-rings on bolts as well for additional lash points.
was looking at the FJ ones. Looks like great way to hang a cargo net above.
Friggen 20 bucks a one... :rockthrow: ....ill pay it too!:lmao:
We sleep in the back. You can look at various trips via the link in my signature. Longest one was 21 days of which 18 nights we spent in the back of the truck.
There are no issues with odor or moisture - crack the rear window and the spoiler keeps rain and such out while still giving good ventilation. You can get cheap screens for the rear door windows if you are in a warm, buggy area.
The only "issue" is storage of stuff while you are sleeping in the back. We basically move everything in the front seats, have other stuff in 8 gal Action Packers in the footwells (see below), and leave our cooler (Grizzly bear resistant cooler) outside. If we have a ton of stuff, anything left over goes under the truck (if it's raining or in an area that gets dew in the mornings) or gets tossed in the roof basket overnight. During the day everything goes back in the cargo area.
I have a non 3rd row SR5. I assume the TRD Pro is also non 3rd row with no sliding cargo tray? If so, the trick is to remove the 2nd row seat bottoms (4 14 mm bolts, easy), fold the 2nd row seat backs all the way forward, remove that fascia panel that covers the "hump" (2 10 mm bolts), and then install some sort of riser in the cargo area to elevate it up 2.5" to make it in line with the folded 2nd row seat backs. This gives you the entire area for sleeping and makes it totally flat. Removing the seats and fascia and sliding in the riser panel takes 10 minutes and they reinstall just as fast.
My solution to the cargo area riser was to build a "pallet" out of 2 sheets of 1/2" plywood set on top of strips of 2X2" wood (which is actually 1 1/2", so this gives you a 2.5" height). Other people try and pad the area with stuff, which I think isn't as useful.
If you need more length you can move the front seats forward and place 8 gallon Rubbermaid Action Packers in the footwells, this gives you about 12 more inches for about 6.5' of length.
We then have a "full" size air mattress and bedding that we use to sleep on. The thoughtfully placed AC invertor makes inflating the air mattress every night easy. In really cold weather we use the air mattress, bedding, and sleeping bags. In really really really cold weather we use all that and run the truck as needed overnight to use the heater.
After doing it this way for a while there is no other way we'd want to do it. Setup and break down is super easy, takes like 5 minutes; we are totally self contained so we can camp anywhere including renegade camping at businesses and so forth; we are well protected in the truck with ready access to heat; and most importantly we are really comfortable.
On solo trips I use the pallet and 1 Rubbermaid Action packer and I use 2 Thermarest pads stacked on top of each other. I leave everything in the back, on one side of the cargo area, and I sleep on the other.
Since this photo was taken I have added 6 Harbor Freight D rings to the corners and center of the pallet to secure cargo. I also figured out that flat stuff can be stored under it so in those slots I have an axe, machete, and folded up tow strap. Lastly, I painted a mock up of the US ion the pallet and I note on there every trip we take so it's kind of a cool memento.
I recently purchased a 2018 Limited 4R. I'm considering a solo trip to Mtn Rushmore camping in my 2018 Four Runner. How safe would it be to run the engine all night during extreme temps? I have a -20 North Face bag and a ThermaRest which should be very comfortable in the back of the Runner.most cold nights... but the nights in North and South Dakota can get pretty dangerous.
I think it's perfectly safe as long as you're careful where you park (not over dry grasses, tailpipe not obstructed, somewhat open area to allow for breezes).
The exhaust will have some condensation in it by morning but that's nothing a spirited romp can't blow out the next day.
If you sleep in the back of your 4R in very cold weather pay attention to your pad. You actually lose a lot of heat there. In fact a lot of sleeping pads advertise their R ratings. For pads I use two side by side thermarests under an Exped Synmat Duo LW (for two people). It fits the backend of the vehicle perfectly for my platform setup. (78x52x2.8 inches). It’s not the warmest pad system but it works for me and wife with good 3-season sleeping bags. Just wear more clothing layers if needed, and a stocking cap. As long as you’re out of the wind your sleeping/insulating system should work just fine. A bigger annoyance is ventilation. You need some airflow and window(s) cracked to keep it fresh and minimize condensation on the windows. You’ll have to experiment. I use a large 12 volt computer fan plugged into an accessory outlet to help circulate the air.
You may want to pre-warm the truck by running the heater, but I wouldn’t sleep with the engine running. Plus, with the proper sleeping equipment you’d get too hot!
I assume the 5th gen is same or longer in size as my 4th gen setup (with double-decker cargo shelf)
Alternative (and easy) setup for one person is the camping cott from bass pro (or similar).
Might need to take out the second row seat bottom on one side or park with the rear higher so that the dip is where your feet will rest overnight.
1 minute setup, minimal intrusion on "under-cott" storage.
Only downside is that you lose the 10-12" of headroom when sleeping due to the height of support legs.. but what you lose there you gain in under-bed storage space.
Alternatively, you can find cotts with much shorter support legs.
In theory, with all that extra space, I have a tonne of extra space and would be comfortable using an old boating trick with the terracotta pot + candle(s) space heater trick with the front or sunroof cracked.
Maybe one day, the 4runner will come with a hybrid electric drivetrain of sorts, and have an electric AC and heating system like the Teslas do.. burn through 10miles of range in exchange for a full night of AC or heat.
Removable bed and storage system
I made a bed and storage system for my 5th gen.
the whole thing is made out of 3/4in ply and covered with indoor-outdoor carpet.
*** Let me know if you would like to see the plans including dimensions and future ads ons.
Like many of you, I have sought out to level out the back of the 4Runner using a simple sheet of plywood on some runners. I also wanted to add some storage to it while maintaining room to sleep in and didn't want to lose too much space, so behold the pictures below! Full disclosure: I do not have the time, skill, or resources to build this myself so I paid a pretty penny to have it done. It is based on and built by the same guy who did this: Building a 5th Gen (2010+) 4Runner Storage Platform – ADVENTURE TACO with a custom twist.
The drawer uses these: Firgelli Automations Full Extension Ball Bearing Drawer Slides 400 lb Capacity (36 Inch) - - Amazon.com
Here is my simple setup.
I lay my Exped mattress straight behind the drivers side and sleep with head at tailgate so my feet can lay off the end. If I go straight then the mattress is a little too long, but still works because I can hang my feet off.
Hi guys,
I just wanted to share my camping solution. I bought 1" extra thick exercise pads and cut them size to help level out the rear cargo area. I has a little bit of give for padding but not much. Its very lightweight and very durable. I'm happy with the results! Works great with my backpacking pad and sleeping bag setup.
I stacked 2 of the 1" pads on top of each other and just locked everything together using the interlocking system and I hot glued them together for extra security. I cut the pads to size.
Amazon.com: BalanceFrom 1" Extra Thick Puzzle Exercise Mat with EVA Foam Interlocking Tiles for MMA, Exercise, Gymnastics and Home Gym Protective Flooring, 72 Square Feet (Black): Sports & Outdoors
I had gotten them for 119.99 on Amazon.
Here was my short term solution. I think I will build out something a little nicer down the road, but I like being able to quickly go back to backseats and family hauler. I just took 3/4" plywood, wrapped it in some cheap outdoor carpet, and then screwed 2" blocks on the bottom for them to sit on. Only reason I have 2 pieces is because that was what plywood I had laying around. In hindsight though, its actually easier to store and move them in 2 pieces.
A 2” or 3” memory foam mattress over the sliding tray. Double wide sleeping bag. All my stuff is put in a tent.
I have an off-road pop-up for the fam... this is my set up just for solo trips.
I’m working on something. I bought a full size bed frame off Amazon for $65. I can easily cut the legs down to length and make it work around the wheel wells. There is room under to store things and it comes apart into two folding beds. 75x54x14”. I just did an initial fit for width, so the bed is not level obviously.
Bought an AirBedz mattress, which is a great idea, but after the second use/night it went flat.
I want something that is comfortable and doesn’t require air. Too many problems with inflatables. I need the width for my wife and six year old son. Also need the length as I am 6’3. This bed does not require a box spring and I need to find a roll up or fold up 3” thick mattress.
Will see. Maybe I’ll call it the HoYo. Goes together easy without tools.
I made a simple folding platform. Fold up the left seat, fold out the platform, roll out the sleeping bag.
Used it one night (the trial run). Didn't use it on the trip.
It's now part of the chicken coop.
Sent from my SM-G955U using Tapatalk
I have removed the back seats of my 4runner and replaced them with a platform made of 1/2" plywood covered with cheap Home Depot carpet. I have added a 6" piece behind the passenger seat on a piano hinge with a kickstand. When it's time to sleep I move the passenger seat forward and swing the hinged piece up supported by the kickstand which allows me to sleep in back without touching the rear hatch. I'm 5'-10" and have plenty of room. I sleep on a 2" thick thermarest pad and a sleeping bag. Works well and adds nice protection from the wind. No more flapping fabric waking you up at night.
Sounds great. Can you snap a few photos to show us?
Sounds roomy. Have you measured the length from front seat to closed Hatch? I need the back seats during the day and am trying to get an idea of whether I should plan on removing seat bottoms for sleeping.
Sent from my HD1905 using Tapatalk
Cpn2mss
