Anyone have a copy of a window sticker for a 2007 T4R Sport V8?
ice2000
Does anyone have a copy of an original window sticker with the MRSP pricing, factory options, etc. for a 2007 T4R Sport Edition with a V8? What does the Sports Edition offer over the SR5 for the 2007 T4R?
Based on the options available for the 4x4 Sports Edition V8 (8686), I have:
__ Anti-Theft Alarm
__ Moonroof
__ Rear Spoiler
__ AM/FM 6 disc with Sat
__ Double Decker (but with no net)
__ 7 pin to 4 pin Adapter
I'm not sure about:
__ Daylight Running Lights (DRL)
__ HomeLink Transceiver
__ Auto-dimming rearview mirror
__ 115V AC Outlet
How can I verify if I have these options?
Thanks!
__ Anti-Theft Alarm Roll Window down, lock car, open door through window, you will know then
__ Moonroof Sit in front seat, look up
__ Rear Spoiler Look at rear of vehicle above rear window
__ AM/FM 6 disc with Sat Look at Radio, will say 6 disc
__ Double Decker (but with no net) Open rear hatch, see if the floor can be picked up
__ 7 pin to 4 pin Adapter Look underneath rear bumper on driver side
I'm not sure about:
__ Daylight Running Lights (DRL) turn vehicle on in daylight, walk to front of vehicle and look at lights, if on without turning on, there ya go
__ HomeLink Transceiver I believe this is a built in Garage door opener, look for buttons on sunvisor or map light cluster
__ Auto-dimming rearview mirror at night if your rearview dims auto when a cars headlights are behind you, you have this
__ 115V AC Outlet to left of stearing wheel above knee if a button says 115V then you have this
Thanks!
These are all very obvious things
__ Anti-Theft Alarm
__ Moonroof
__ Rear Spoiler
I'm not sure about:
__ 115V AC Outlet
Thanks!
Let me clarify: I want to verify if I have DRL, Homelink Transceiver, Auto-dimming rearview mirror, and the 115 AC Outlet options. Thanks for your help.:snacker::thumb3:
__ Daylight Running Lights (DRL) - when the vehicle is running both of your front blinkers will be lit up (not blinking just on)
__ HomeLink Transceiver - 3 small buttons on the overhead console, can be programmed to open the garage door or gate if you have one
__ Auto-dimming rearview mirror - mirror dims and makes headlights greenish when someone is behind you at night, I think most also have a compass and some buttons while then non-dimming mirror doesn't have any frills.
__ 115V AC Outlet - AC outlet in the center console near the bottom on the passenger side
Thanks! The move from a 3rd Gen to 4th Gen has me exploring the "upgrades".:thumb3:
I see the 3 small buttons on the overhead console near the sunroof button= Home Link Transceiver CHECK.
I figured that the 115V AC Outlet near the center console was standard equipment; I found a AC Outlet in the back near the right side panel.
Thanks!
No it was an option. Are you talking about the 12v plug by the shifter or the 2 prong AC outlet on the inside of the console?
Where is your rear ac outlet? I only have the one in the console.
The one by the shifter. I'll check to see if there is one inside the console.
The rear AC outlet is located on the right rear quarter panel near the rear gate.
