I have my sticker for my '07 Sport V6.
Also, you can find MSRP pricing at the spreadsheet I have posted on Toyota 4Runner Purchasing and Invoice Pricing
These are all very obvious thingsBased on the options available for the 4x4 Sports Edition V8 (8686), I have:
__ Anti-Theft Alarm Roll Window down, lock car, open door through window, you will know then
__ Moonroof Sit in front seat, look up
__ Rear Spoiler Look at rear of vehicle above rear window
__ AM/FM 6 disc with Sat Look at Radio, will say 6 disc
__ Double Decker (but with no net) Open rear hatch, see if the floor can be picked up
__ 7 pin to 4 pin Adapter Look underneath rear bumper on driver side
I'm not sure about:
__ Daylight Running Lights (DRL) turn vehicle on in daylight, walk to front of vehicle and look at lights, if on without turning on, there ya go
__ HomeLink Transceiver I believe this is a built in Garage door opener, look for buttons on sunvisor or map light cluster
__ Auto-dimming rearview mirror at night if your rearview dims auto when a cars headlights are behind you, you have this
__ 115V AC Outlet to left of stearing wheel above knee if a button says 115V then you have this
How can I verify if I have these options?
Based on the options available for the 4x4 Sports Edition V8 (8686), I have:These are all very obvious things
I have the DRL's and they are a bright amber. You would know if you had them.
__ Daylight Running Lights (DRL) - when the vehicle is running both of your front blinkers will be lit up (not blinking just on)
__ HomeLink Transceiver - 3 small buttons on the overhead console, can be programmed to open the garage door or gate if you have one
__ Auto-dimming rearview mirror - mirror dims and makes headlights greenish when someone is behind you at night, I think most also have a compass and some buttons while then non-dimming mirror doesn't have any frills.
__ 115V AC Outlet - AC outlet in the center console near the bottom on the passenger side
No it was an option. Are you talking about the 12v plug by the shifter or the 2 prong AC outlet on the inside of the console?I figured that the 115V AC Outlet near the center console was standard equipment; I found a AC Outlet in the back near the right side panel.
Where is your rear ac outlet? I only have the one in the console.
