anyone have part number for plastic radiator cover buttons?
keakar
every time i try to get those snap buttons for things i always seem to buy the wrong size ones
does anyone have the part number for plastic radiator cover snap down buttons to lock it in place? there are 11 of them and i am trying to do this online rather then drive 45 minutes to the nearest dealership to order them
the official name for this part is SEAL, RADIATOR SUPPORT, UPPER (part #53292-35010) but toyota isnt showing the snap in locking tabs for it
thanks for any help you can give
Guide clips.
Guide clips.
i guess, not sure what they are called
its that black plastic cover that helps direct air into and through the radiator and not let it pass over the top of it
anyway there are 11 of those buttons you push in the hole, then press the center part in to snap it in so it locks itself tightly in place
Like these? I had to replace a few when I did my bumper install.
https://www.oempartworld.com/oem-pa...uZXImeT0yMDA1JnQ9bGltaXRlZCZlPTQtN2wtdjgtZ2Fz
Also called fastener rivet clips.
that is for the bumper stuff so i dont know, each of those clips is for a different diameter hole. the fender skirt is on size, the bumper skirt is another size, the bumper trim is a completely different size from the other two and its like that all over the place. they make life so hard when they should just use one size hole for everything and one snap fastener for everything, but then that would make way too much sense lol.
near as i can tell they come in 8mm, 10mm, 12mm hole diameter sizes, and then they have all sorts of different depths they grip at, some pull flush tight and some go in 1/8" or 1/4" before they grip, so that adds even more frustration to getting it right.
thanks guys, i just ordered a set of them
sometimes its easy to find part numbers and then sometimes its not easy at all to find them
