Anyone install a Midland MXT275 in a 5th gen?
Has anyone hardwired their MTX275 radio to the fuse box or the actual battery? The cables upfront are such an eyesore..
Not a big fan of cables out in the open either, I kept it simple and ran the wire over the top of the hvac and to the back of the glovebox, popped the blank out (where a usb might be on other trims) and plugged it into the 12v plug. Out of sight and easy to remove.
All I have to do is pop out the blank? There's already a 12v plug back there?
Picture :) inside the glovebox, I may of started here and fed it through, can’t remember, check to see if the plug fits through the knock-out
He popped out the blank to feed the plug out and then plug it into the 12 volt socket in the dash. The radio comes with a cigarette-lighter type plug.
Ah, my 2021 ORP doesn't come with it from factory for whatever reason
Yep, mine doesn't either. And that's why I jumped on the idea that he had brought it out of the dash (although, I was kinda stabbing at that without looking at my own dash.)
Sorry for the misleading.
Wouldn't be too terrible to wire in a socket in there if you wanted. The holes are already there. I wonder if there's a loose connector behind the glovebox just waiting to be used?
Now I'm curious...
Those cheap "basturds" :D As mentioned, you could pop it out with a trim tool and see if it is wired for it, if it is you could either buy an OEM plug, buy a mating connector or just tap it as is, cross fingers.
i just ran the cig plug to the one of the empty ones behind the center console.
Another buddy, did a ghost install by drilling a hole into the center cubby and used the cig plug in the center cubby.
Although i like your idea more..just gotta get my lazy ass to actually go poke around in the glove box.
I am thinking the head unit can fit perfectly in the dash space right above the front cup holder.
Photos of your setup?
I mounted my Midland MXT275 in the glove box like shown on their website. I ran the power wire to my sPOD in the engine bay and run it via my sPOD. I bought a antenna off of Amazon that mounts on my Prinsu roof rack and can be folded down between the cross bars of the roof rack when not needed. I routed the antenna wire through the passenger side firewall and up the A-pillar.
got a link for that foldable antenna mount? I would greatly appreciate it.
As soon as they become available again, I'll buy one and let you know what I came up with in regards of installation.
The 275 and Ghost antenna are both backordered.
i have a 2012 TE and didnt know that was in there hahaha. i think i may copy this...where is the unit mounted? what antenna setup did you go with? the 275 comes bundled with a mag mount which i think i will use for now, but would like to go with the ghost antenna at some point. gotta figure out what mount will fit the TE roof rack though.
