Anyone mount a solar panel to roof rack?
I have a Renogy 80w panel mounted on the cross bars on the stock roof rack. I just drilled holes in the end and use little bolts to attach it.
I ran 10ga wire through the grommet in the back hatch and down to the charge controller in the back right storage spot. I have 4gauge running back to the same compartment to a big fuse box. I just connected the solar there so I didn't have to run it to the front.
Here's the two options I always recommend when running wires from the roof inside:
- Run the wire to the back and use the grommet for the hatch. The only downside is the amount of wire needed.
- Run it through one of the holes already existing under the endcaps of the stock roof tracks. Pull the little plug out, and there's a hole that goes directly into the headliner.
knowledge rarely has an expiration date. Plan on a mounting a removable solar panel on the roof with permanent wiring in place, running to a controller inside by or on the interior ceiling by the hatch, with a second set of wiring to connect to the controller for moving the panel around. That a hole is under the rack endcap will be handy, thanks.
Since my old thread keeps living ill add this.
I still have the 80w panel wires going into the rubber grommet on the hatch but I also have a led light up there on the roof and I ran the wires along the rack an then ran them down the hatch lines to the rear tail light and went into the car that way. I wish I had a picture to describe it better.
One more thing to add. I used speaker wire from the solar panel and the wire is now very faded and damaged from the UV rays. If you can use UV proof wire.
wayblom
