1. Hard-On™ Permanent hard coating
Hard-On™ Permanent hard coating-wwho
-Woolwax Hard-On is a high performance, permanent 1-time hard shell coating. NOT rubber.
-This coating is not intended to be removed (be certain that you want a permanent coating).
-Expected life expectancy is 5-10 years depending on use.
-Acts as a sound and vibration deadener.
2. Creep N' Crawl Cavity Wax
Creep N' Crawl Cavity Wax-wwcc
-Creep N' Crawl™ has no solvents or fillers. It is 100% solids which means that every raw material in the formulation is effective as a corrosion inhibitor
-There is nothing to evaporate. so if you spray on 1-2 mil thick, you will be left with exactly what you sprayed on the surface.
-One coat in the enclosed cavities and you will never need to treat that area again for 5+ years.
Looks very interesting, been using woolwax/fluid film but curious if anyone tried these out?
