Anyone using Toyota 90915-YZZD3 larger oil filter?
BamaDrewski
Just curious if anyone is using the Toyota 90915-YZZD3 on their 3.4? If so, what is the increased oil capacity/refill? Thinking of trying this larger filter on my 2000 T4R.
Solution
Yes, I switched my 3.4 Highlander over to it so only have to stock one filter.
Make sure you fill your filter with oil before you install it, takes about 3 fills to the threads before filter quits absorbing all the oil, this way you don't have to worry about how much more oil, just add the 4 Q's and you're good to go.
Also the filter doesn't have to fill on initial startup, it's already full.
I have been using the D3 on my 3rz pretty much since I bought it 5 ish years back. A little more oil in the system, a little more filter media, lots of room for it. No reason not to.
I haven't measured the difference in volume but I would guess it to be about 200 ml more. It doesn't change the number of quarts I have to buy for an oil change anyhow, just a little less left over.
I use the oversized and all-synthetic NAPA Pl.41516. Expensive, but I use Supertech oil and run it 7500 miles. 200k and going strong and great Blackstones. Been doing it this way since 100k
I'm using the oversized Napa Gold (Wix) 1516 filter. It's equivalent to the Motorcraft FL400. Works great and I like stocking only 1 filter because I have two other Fords in the family that use this filter.
Is the supertech synthetic or regular? I’ve been using the Motorcraft semi-syn lately.
Solution
Difficult to do when you have to invert the filter to install it....
I use a wix synthetic oversized filter too. I change it every other oil change. Filters get more effective as they load up, until they are stuffed!
I have to ask if you are going by miles there, when you need to change the oil but not the filter. Considering I have seen how well your top end looks thanks to Tim and Sean you must be doing something right :behindsofa:
I use the Bosch D3422 and have for some time......
I used it. You won't notice anything other than a piece of mind.
Whoops did I say that? I meant to say seems like it runs smooths, shifts better, I've been getting 2-3 more miles more per tank(give or take ;) ), and it soaks up the bumps better. Oh yeah and I changed my spark plugs the day before that.
