Anyone using Toyota 90915-YZZD3 larger oil filter?
BamaDrewski
Just curious if anyone is using the Toyota 90915-YZZD3 on their 3.4? If so, what is the increased oil capacity/refill? Thinking of trying this larger filter on my 2000 T4R.
Solution
Yes, I switched my 3.4 Highlander over to it so only have to stock one filter.
Make sure you fill your filter with oil before you install it, takes about 3 fills to the threads before filter quits absorbing all the oil, this way you don't have to worry about how much more oil, just add the 4 Q's and you're good to go.
Also the filter doesn't have to fill on initial startup, it's already full.
alexaturner
