Approach & departure angles
patkelly4370
Had a sheet of plywood laying around. Thought I would see what the A & D angles were with my 4runner.
Rear suspension appears stock, front too but with a 1½" leveling spacer. Tires are 285/70r17 Toyo.
Sent from my SM-G955U using Tapatalk
Am I missing the part where you share the results?
No, didn't miss anything. I wanted to see the angles (I'm a new T4R owner) and thought I'd share. But there will be results in the future.
2017 SR5, 22,000 miles, I've had it 2 months. It came with 285's and 1½" leveling spacer up front. The rear is OEM.
I need to drive it more to decide how to best make it as efficient as possible for me.
Stock approach angle is 33 degrees and a departure angle is 26 degrees.
So the spacer and larger tires should increase both angles a bit...
DionicioLives
