ARB Air Locker install video, done mostly correctly
Great video. It should be really useful for DIY folks who might think it's something outside of the realm of home mechanics. If you're not changing gear ratios, it's not a terrible job since you don't have to reset pinion depth.
My only comment is that if you're using OEM gears - the spec is .010 - .020 backlash. Most aftermarket gears are .006-.010. So if you look at a typical gear setup chart for the specs from Yukon or Nitro or whoever, it'll say the tighter backlash setting. I think for most OEM gear sets if you set the OEM gears around the .006 range, you're probably going to get a bit more gear noise and paint a pattern that shows the pinion being a bit too deep. It'll probably work fine, but for OEM gears I'd probably measure first, then setup the same backlash when finished. It's a little unusual that your original measurement was closer to .006.
Also - I have no idea why Toyota uses shims on the non locker 8.2 but threaded backlash adjustment on the elocker diff.
If you have a good understanding of the how and why, this short and to the point video was a perfect explanation. Thanks for sharing OP!
H.Sikina
