ARB engine bay mount?
tubbs831
Looking for options to mount an ARB and fuse block in the engine bay. I know there are some out there and i have seen them but i don't know what key words to search. Something similar to the Power Tray option. Any help is appreciated.
POWERTRAY LINK
ARB makes a lot of stuff, but I assume you are referring to the air compressor?
You don't need everything to go on the same mount... most installs I see for the air compressor are on the passenger side with most general electrical on the driver.
Some systems require a PS relocation kit depending on the generation of 4Runner and the pump you select.
"(x)th gen 4runner arb compressor mount" would be a good place to start.
As for the fuse block, unless you are running a variety of electrical accessories, you could get away with less if its just the compressor, or you could buy into a system.
You have a lot of options, including just making something custom, which is what I did.
A good starting point would be to list out all the electrical modification you want to make first so you can pick a load center that works best for you.
Yes, it's for my 5th gen and I have the fuse block right now but am looking into the single compressor and it could fit on the passenger side together. From the link I posted before.
Would you mind sharing what you made?
Sent from my SM-G950U using Tapatalk
If the bracket you posted works for you, then I would say you already found what you need.
I don’t really have good work in progress photos… I just walked around Home Depot and bought various metal angle and L brackets and drilled them out to make it work under the hood to hold various items securely.
My air compressor isn’t under the hood for longevity / heat concerns. I have a portable on an Anderson quick disconnect in my grill.
I'm actually inflating my air mattress here... but you get the idea.
