"Armored Pig" Build Thread 2002 Sport
Electrical Love #2
Built radio harness for new deck.
Pioneer DEH-80PRS installed, suppose to be a good set up, see what happens when the infinity speakers get here
Now the fun part test fitting the panel, Led Carling switches, and Pioneer
then started wiring in the the bushman relays to the switch panel
Power tested everything and put it to a meter, then made a by pass for the power antenna, now the mast can be raise and lowered when needed
All buttoned up and matching the ARB locker switched, which were converted to the newer carling Leds too.
Lots of good stuff going on here! Any chance you could snap a pic of the dual battery setup and where you mounted the IBS system? I have been debating the dual battery setup for awhile but have yet to "need" it...but the insurance of having it for solo runs is kinda what keeps me thinking about it.
Ok only down side was some of the wires were a heavier gauge than needed and a little long. Now the Best Solution.... Dual battery try Kit from Columbia overland, fits 2 Odyssey PC1400. (by the way the Diehard was a rebranded Odyssey before they discounted the line)
IMG_5048_zpsdita3a7p.jpg~original
How do you like the Columbia dual battery tray?
Those Kings are sweet. I am curious to know your opinion of the ride compared to the bilstiens
I put white LEDs in mine, I would try that before going back to stock bulbs.
Where do you get these and are they difficult to install? Thank you! New 4runner owner here :)
Awesome build!
Questions.... how do you like the 4.56/285 combo in California? I need to regear and I'm stuck between 4.56 and 4.88 (have 4.10) now. I'm going to be going with 295/70/17 so just a touch bigger but we have so much freeway here in CA, so I'm really stuck here. Supercharger would be at least a year out.
Also, how do you like the 700lbs spring? I ordered mine with 650lbs spring, but now I'm starting to second guess myself with sliders, roof rack, plate bumper ordered and eventually a synthetic line winch. I'm thinking maybe I should have sucked it up and got the heavier spring to start and not have to upgrade later. Also hoping that maybe the 650 will still be ok with everything.
Well some of the photos have been migrated, the rest will follow. Time for new project, makes oil changes a little easier.
So Sonoran Steel Rear body mounts were installed
old mounts looked beat
New SS rear mounts VS old oem mounts
buttoned up and all new
Also found a old picture of Project "Sleepy" pre long travel but after Lexus V8 1uz
Amazing 02 I've had one for the last 2 years but school and life kept my from spending money on it but now im ready! Have you given any thought to a 5speed swap on this beautiful rig?
more likely to try a 2uz swap than a 5sp, figure if i am going to have to figure out wiring again, might as well make it worth the time and effort..... plus might have a line on a 2uz
Guess its update time. Little pre trip before the big tear down last year
Zion, Capital reef, Bryce, overland 2018, horseshoe bend and a pit stop in vegas.
National parks camp grounds are worth it
Narrows.
angel's landing.
capital Reef 4x4 trail.
Bryce overlook
seltzernator
