Attach rails to tailgate glass
oconshaw
I have a 2000 4Runner and have a problem. The tailgate window started giving me problems lately so I took it apart to find that the window had separated from the regulator. The glass is OK, but my problem is the glass became separated from the rails that look to be glued onto the window (and then fit into a channel on each side of the regulator). Any ideas on what to buy to fix that? The rails themselves seem OK, but I either need to get new ones (what part to buy?) or figure out how to glue them back on like they were before. Any ideas? Thanks.
I'm pretty sure those parts are available separately, not sure how they're attached to the glass though. You'll need to know if you have A or B style when you order (two different configurations)
If the parts are still serviceable perhaps Gorilla glue is worth a try? Worth a try before you spend money on new parts.
Thanks for the reply. How do I tell if it is A or B style? I don't even know what the part is called to make the order. Or how to attach. It looks to me like the rail that is attached to the glass has some rubber like material that is either the adhesive itself or the rubber is attached to the rails and then the rubber itself gets glued to the glass. I can't tell. I don't think gluing the glass to the rails is the best approach -- I think the rubbery substance helps with the vibration and jarring that the glass would experience against the rails; without that I am pretty sure it would vibrate off the rails with just the gorilla glue.
Are you talking part 69907E? or the part that attaches between that and the rails? If it's the part that attaches to the glass that's where you need to choose between A and B style.:
https://www.toyotapartsdirect.ca/a/Toyota_2000_4Runner-SR5-0008-BASE0008--3400CC-EFI--AUTOMATIC-4-SPEED/_52022_5893382/Back-door-lock--hinge/671122C-6762-671460.html
OK, thanks for that. It is part B. The parts I have look OK, but one of them has become detached from the window. I don't know how to properly reattach or if I need a new one. Maybe the new part comes with the rubber stuff and directions on how to glue on?
Camelback often describes the part and whether it has a blue peel-back glue strip included or applied. Check there https://parts.camelbacktoyota.com/
EDIT
[ 5 ] BODY HARDWARE / LIFT GATE / GLASS & HARDWARE / Glass holder
Part Number: 6990735041
glass holder HD Right
PARTS: Part included with glass.
Guess you might want to glue it yourself as it's a $38 part, but call them
Ahh, so that's it then -- the new brackets must come with the rubber. It sure looks glued on to me though. With the bracket off there is a lot of hard residue on and around where the rubber from the rail should contact the glass. Maybe I am not remembering correctly -- I'll have to go back and look at it gain.
I just had my back hatch apart, and I remember it looked like 3M Windo-Weld Round Ribbon Sealer to me. I did not mess with it. black sticky gunky stuff.
