Autbond
Yes he did, I am a little peeved because he didn't say anything about them being at their limit. So, I can get a stiffer spring in the front to support some weight? How much will that cost when it comes time to get them?I didn't mean to freak you out or put down OW by any means. The 2.0's are meant to provide 3-3.5" of lift on a truck without a bumper. They can still be used on a vehicle with a bumper as Mark told you, it's just harder to do (i.e., you must crank them much more).
The 2.5's have a larger shock body which allows for better cooling when doing faster style offroading. The 2.0's will heat up faster which will cause them to fade and have poor handling. Since you don't do that style of off-roading this is irrelevant to you.
If you get skids or anything else that will add weight to the front, you will need to do something with the coilovers such as upgrade to the 2.5's or get stiffer springs installed onto the 2.0's. The bumper paired with your V8 is putting those 2.0's near their limit. Did Mark know you had a V8?
