Autobody Shop Triggered Driver Side Airbag Light !?
N0RTHWEST
Hello guys!
I recently picked up my 4runner from the shop. 2015 Limited.
They replaced my rear hatch door (dent) and paint matched the trd pro front and rear bumpers I previously installed on my vehicle. They also cleaned the interior.
The airbag light has been on since I picked it up.
I assumed it had something to do with the battery as I noticed the clocks were off. Figured they unhooked the battery or something as to not kill it. The light remains on after 3 days and I'm starting to worry. The guy said nothing they did would have triggered that but we will talk next week.
I'm hoping this is a simple fix but I'll raise hell if necessary.
In the meantime do you guys know anything that can be done to reset it or maybe it was a wire they bumped? Fishing for ideas.
Thanks!
edit: Just purchased the obdlink mx+ and see if that works resetting the code?
did they unplug anything on the dash?
is there something sitting on the passengers seat or did the passengers seat come out?
Bring it back to the shop and let them fix it. If you want to fix it on your own, you should start with a scan tool that is able to talk to the SRS system and retrieve the current fault.
Most likely it something left unplugged, which the SRS fault should quickly guide you to.
patnewton
