NickMiller
I have an 88 4Runner 3.0/AT.
I have no overdrive unless the temp gauge reads 1/2 through. The second it drops below that mark, it kicks out of OD. When I first got the vehicle it would shift into OD when the gauge read about 1/4" the Low mark. When I get on the freeway it cools down significantly, so it won't stay in OD. I've resorted to cardboard in front of the radiator....still doesn't work right.
I understand the temperature/OD minimum that Toyota has done.
I've put in 2 different thermostats, replaced the temp sensor, and flushed the system.
It also doesn't blow warm air at idle, I have to rev it up to about 2000 rpms to get warm air from the heater.
I've run out of ideas, and hope someone might have a fix for it....
