Aux trans cooler stealth leaking?
NoVA_T4R
Member
Hi all,
I've had a B&M trans cooler installed (bypass radiator) since 2015 and had no trouble until recently. I've had a very slow leak that I've noticed after parking overnight. I tightened the B&M provided hose clamps, then replaced them with appropriately sized 3/8" spring steel worm clamps, but it's still leaking.
I'm getting ready to move the ATF hoses back to the radiator and delete the B&M cooler, but was wondering if anyone has experienced the aux cooler leaking unexpectedly? No exterior damage to the B&M as far as I can see.
Thanks in advance!
Did you clean all the residual transmission fluid off the fluid lines when you changed hose clamps? If not I would start with that and check for your leak after cleaning it and driving a couple times.
To Mark_BC:
No fittings, just a straight connection from the ATF hose to the smooth B&M cooler connections (smooth just like the factory radiator connections).
No leaking anywhere else except at 1 of the B&M cooler connections.
To BadLuck:
While I did not wipe out or rinse off the residual ATF fluid on the tray beneath the radiator, there is a constant leakage. Every night I put down newspaper beneath the B&M cooler side of the radiator and there's a small circle (~2-3") of ATF fluid on the paper in the morning. Over a month, it was enough to drop the fluid level on the dipstick from the bottom of the COLD range to about 1/8" below the bottom of the COLD range.
I am considering replacing the hoses, but it's been less than 4 years after installing the B&M with NEW ATF hose lines. Since it's only leaking at the B&M cooler connection and not at the trans pan send line area, it makes me consider it's something with the cooler. I do ATF fluid 1-for-1 replacement every 60K miles and did a drain and refill just 200 miles ago, and the fluid looked dark red and not burnt.
To LittleCaesar:
BTW, what about NoVA climate makes it worse for hoses than, say the desert southwest or the rustbelt area? Just curious what you know that I'm not aware of.
To Mark_BC:
To BadLuck:
To LittleCaesar:
The change in humidity over the course of the year, from cold weather and snow to the blazing summers don’t do well with rubber.
I purchased some ATF from Advanced Auto. Terrible stuff, leaked like a sieve despite being 3/8”. Find a named brand hose to use IMO.:heh:
What I'm running right now is Autozone 3/8" non-branded bulk ATF hose.
Not sure what is named brand hose or what names to look for.
Amazon has a Derale named ATF hose.
Napa parts has their in-house hose at 5/16" inner diameter.
Would appreciate any brand names and if going down to 5/16" is part of the solution.
Unusual issue - system doesn't develop much pressure, so does the 3/8 slip on easy? If so then Yes I'd say move down to the 5/16, Gates or Grainger brands but I think it's more about size and making sure its a hose meant for oils. Luck. :cowboy:
Derale is not bad stuff, I have used their line before with success.
Would I go down to a 5/16” hose? No, I would just get better hose and be finished with it.
It turns out there was a small crack on the back of the B&M aux trans cooler facing the AC condenser.
So I deleted the B&M and went back inline to radiator.
There did not appear to be any impact that caused the crack. So I'm not sure whether to go back to B&M in the future.
3/8" hose was just very stretched to the point where it was a loose fit on the 3/8" fittings on the B&M. I will definitely go with Gates (which is carried by Napa Auto Parts BTW) in the future. The existing 3/8" hose was from Autozone.
The 5/16" hose I brought along would be considered cruel and unusual punishment to try to fit on both the B&M as well as the transmission send/return hard lines. It's definitely 3/8" hose for this application.
Thanks for all the replies and input.
boy I could swear I used 5/16 with a 5/16 magnafine filter with no issues, why do you say cruel and unusual to use 5/16
The B&M kit comes with 11/32 hose which is a hair smaller than 3/8. I think trying to fit 5/16 hose on the cooler barbs and 4runner trans lines would be quite frustrating.
"Quite frustrating" is an understatement of putting the 3/8" hose on the trans lines and the B&M fittings 4 years ago.
5/16" is in the realm of possibility, I suppose, but the 3/8" I already installed held up solid. If you need to combine a chest, shoulders, and arms workout to your trans cooler install/maintenance while paying for a lift by the hour, then 5/16" it is.
I didn't use the hose supplied with the B&M kit since it was only long enough for 1 of the lines to the cooler. Went with the Autozone purchased hose for both runs to/from the cooler.
mek
