Axle Seal Replacement = Alignment?
81reaper
I just replaced both front axles on my 2004 SR5.
With new inner axle seals sitting on my bench, I made the stupid decision to not put them in.
My reasoning was, "if it ain't broke, don't fix it".
Well, now it' s broke. The passenger side leaked overnight.
Can anyone tell me the best way to replace this seal without requiring a 're-alignment? I had it aligned yesterday and don't want to pay them another $65.
Thanks.
Why would you need an alignment after replacing axles or axles seals for that matter? Those parts don't affect the geometry of the suspension...
I am talking about the front axle/cv joints.
TRDCal, it's not the axles that concern my alignment, it's my path to them. I assume the best route to them is undoing the lower ball joint, but does this alter the alignment?
All of this was replaced during the installation of a lift kit and many other parts so getting to them without affecting my alignment wasn't a priority the first go around.
Thanks jstutz101, I ran across that guide but was unsure as to whether or not disassembling the lower ball joint altered the alignment.
Thanks for clarifying. I will use this method. Hopefully I will only be out a little gear oil.
Oh I see, I guess I just misunderstood. I see you got your answer. Good luck with seal replacement.
Thanks guys.
I'm not touching anything just yet. The drips have stopped, so maybe a few more warm up/cool down cycles will seat the old seal to the new shaft.
Feeling hopeful for now.
