I'm pretty excited to get back to a 4Runner. This is my 2nd 4Runner and 4th Toyota overall. I had a 2004 4Runner and loved it but went to an Infiniti FX35. Well, I liked the Infiniti but had to go back to the 4Runner with a 2019 SR5 Premium. So, what are must have upgrades?
I've never modded any of my Runners, but I agree with this approach. Ideally, mods will help take you a little further off the beaten path than stock will. A slow approach will save money and headaches, and will end up getting you what you really want.If I had to do it all over again, I would mod only what I absolutely needed, keeping in mind overall weight and GVM. Off the lot, your curb weight is approximately 4750 lbs. GVM is approximately 6100 lbs. Every ounce of weight you put on detrimentally affects performance.
I would take it out and do whatever it is you intend to do with it. Base your upgrades on that. For example, if you wheel it, do that. If while you're out on the trails you determine that you need extra ground clearance, then consider bigger tires and/or a lift. But first, determine a need for it, instead of just doing it off the bat.
I think this approach leads to better mods, as well as, saving you money.
Most of all, drive it and enjoy it!
