Backspacing and offset
Jaketino
So I've read this thread and am still confused.
http://www.toyota-4runner.org/3rd-gen-t4rs/137316-wheel-backspacing-offset-defined.html
Basically, these rims have a positive offset of 28.5mm. So anything with a lower offset would push the tires out further away from the body, such as these:
Wheel Details - Discount Tire Direct
I'm just curious because I just bought new tires and put them on the stock rims but I want to try and push the tire out a bit and want to get new rims at the same time.
If you are wanting to set the wheels a little further out, just getting a 16x8 will do that if you're comparing the stock wheel. I have found, and read from others, that a 16x8 or 16x8.5 with 4.5" backspacing and -6mm offset is about a perfect combo as you can get. Buy the one you linked...I have that exact wheel (different color) and this is what I got...
This link really helped me a lot
Yeah that is like the perfect stance.
Brian, that link is awesome! Thanks. I like to be able to see the differences between things before I buy.
tuṣṭāva
