Bad Throttle Position Sensor Symptons?
RiFF RaFF
:wave:
Hey guys. My T4R has been getting hard to start after warm-up, and kinda bogs down/backfires while driving.
I've already replaced the fuel filter with no change. My next suspected problem part would be the TPS.
Has anyone been down this road, and is that a logical start?
:flame:
Check your fuel pressures(rest-regulator and running-pump). Ethanol is doing a number on the fuel systems on these old trucks.
regards
Bad tps usually creates a very rough sparatic idle and make vehicle almost and sometimes non drivable. Not sure with these old 4 runners but a lot of vehicles if you have a bad sensor try unhooking it and running it and the computer will use factory default setting for that sensor. Once again I'm not sure it will work but it did on my 93 gmc jimmy I had and it only takes a minute to try it
I always have trouble with that link on here for some reason. But if you copy the link and then paste it into your google search bar, it should be the first link that pops up.
Got it! Thanks again.
Now if we can get some weather warmer than 19 degrees I'll go and tinker with it. I have some goodies I need to add on - cargo rack, HID off-road lights...etc.
The groundhog says an early spring. If he's wrong it's game on!
:sniper:
patnewton
