bad toe in or out idk need help
duckrunner
hey guys so recently I mounted my bilstein struts up front with my toytec coils and now I have some real bad toe in or out idk which one but my tire barely has anything making contact with the ground which is no bueno, so if anybody can enlighten me on how to fix it that would be awesome thanks guys!!
I think you mean bad camber. If you put on a lift, a professional alignment is highly suggested. Otherwise, you are likely to destroy your tires.
Raising the truck will cause the lower control arms to drop in relation to the steering rack. This will cause toe-out, and the camber will change. Have it aligned right away.
