Ball Joints
JHILDE
Junior Member
Looks like I'll be replacing all the ball joints sooner than I thought. The left lower that I had to replace in a parking lot at midnight with a O'Reilly one has started making noise and the steering feels a little off. All the others are original with 374,000 miles, the Oreilly one might have 20k miles. I had planned to do them all when it warmed up some but no luck. Are the part numbers in the following thread the same for 4wd and 2wd? Mine is a 2wd.
http://www.toyota-4runner.org/3rd-g...nner-tie-rods-ball-joints-wheel-bearings.html
They're all the same between 2wd and 4wd. Stick with OEM for the lowers! You can get something other than OEM for the uppers, or at least that's my opinion. I ordered lowers from Toyota Parts Deal, and the uppers from Low Range Offroad. I also order the inner and outer tie rods from Low Range.
I knew the non-OEM wasn't going to last (although I thought I would get a few more miles out of it). It was one of those had to replace it in a parking lot and be have it moved by morning after it failed rather spectacularly.
Might as well go oem on uppers. They are $35.
OEM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Toyota makes great suspension components, that last 10 years. (excluding lifts etc)
same price as aftermarket.
tuṣṭāva
