mrblah
Senior Member
just buy a lithium jump pack to carry
I do
You weren't joking about lead-acid batteries being non-jumpable?? Dude - people jump start cars all the time....:der:
If you drain your conventional lead acid battery in the middle of nowhere u r screwed. I’ll take any agm battery any day of the week for peace of mind, at least it’s jumpable when u need to.
WTF are you talking about? LOL :der:
I’m as confused as you are. :shrug: not seeing the forest through the trees or well even any trees. I guess, I too need a better explanation.
From my experience if u keep draining a lead acid battery there is a point where it won’t retain a charge. Sure you can keep jumping it but There is a point where the battery needs to be replaced.
Agm batteries are way more forgiving in this regard.
To misses Jenkins: believe what u want to believe.
they haven't been debunked by oddyssey, oddysey's warranty is voided because the 4runner doesn't provide the voltage required explicitly in the warranty
Can you provide more details on this and why?
From the Oddysey warranty:
"For applications where an alternator is present, the alternator must deliver between 14.0V and 14.7V when measured at the Battery’s
terminals. Consult the ODYSSEY battery technical manual or owner’s manual for any necessary temperature compensation.
Alternators that do not have a regulated charge between 14.0V and 14.7V (no lower than 14.0V and no higher than 14.7V) will cause
early failure of the Battery. Use of such alternators with the Battery will also void the Battery’s warranty."
Toyota specs for the stock alternator is 13.2V to 14.8V. They typically run right around 13.8V which is the industry standard.
Maybe they don't really care but if what you're buying is a warranty then you might think twice. Personally when I buy a battery I'm looking to buy a battery, not a warranty so I just buy a good quality conventional battery and don't worry about it. Only battery I've ever had fail prematurely in over 30 years of driving was an Optima AGM.
I am not going to fight this battle again. It has been done enough in the past. I will continue to run my Odyssey battery and you run what you want. I never use conventional batteries in anything anymore because once they start to fail they start leaking acid at the post and corrode them. As I stated I talked to Odyssey about this application and they said it is fine.
That's great they gave you a verbal assurance and if you trust them to back it up that's great. I wonder why they don't put it in writing?
All this lead acid, AGM deep cycle, Lithium battery stuff. I've been on the Flux Capacitor since 1985 and never looked back.........
