Been driving a GX 460
Barn door? Think you might be confused with something else. Barn doors are two doors that open left and right. The GX460 has a lift gate.
I disagree. Maybe it's a terminology thing. The 4Runner has a "liftgate" or "hatch" IMO.
The GX470 and all gens of the RAV4 have barn doors. The first and second gen CR-V adds cumbersome that the lift glass needs to be opened before the tailgate can be swung opened, IIRC. To get full access to the cargo area, there is this door nearly the width of the vehicle that swings open, which by my definition is a "barn door".
The GX460 just incorporates a "lift glass" on the door to provide quick access to the cargo area. Similar to how the 4Runner has the roll down rear window that's an added bonus. But to get full access to the cargo area the door still needs to be swung open impeding access from the side when parallel parked.
The 4Runner with the roll down rear window is the best design out there.
Ok, my mistake on the door config, I must have been thinking 4Runner. Must be a terminology thing like you said, I've never heard barn door used for a single hinged door, only for double doors like on this 100 series.
I doubt it. The 4.6 has more torque and HP than the 4.7. It is more a case of power to weight ratios. The GX460 (curb weight 5300 lbs) is even heavier than the GX470 (curb weight 4900 lbs).
its heavier probably from the beefed up frame? i dont know for sure, but doesnt it use the old LX, LC frame? The 4R, FJ and gx all have same frame i thought
Where did you hear that the new GX uses the old LX frame??!! :confused: Does that mean that the 5th gen uses the old LX frame too?
No, it does not. The GX460 frame is a slightly modified version of the GX470 frame with a few enhancements, according to Toyota. Enhancements = relocation of rear shocks, a few reinforcements here and there.
No, it does not use the old LX/LC frame. Nor is the GX frame "beefed up." The GX, 4R, and FJ use basically the same frame. The GX has the V8, which is heavier than the V6. It also has a lot more sound insulation and luxury toys. All that adds weight.
The differences between the 4Runner and GX.
6,500 lbs. tow rating (class 3 WD hitch)
Sequential Multiport Fuel Injection (SFI); Electronic
Throttle Control System with intelligence (ETCS-i)
Emission Certification ULEV-II
Full time 4WD and TORSEN® Limited Slip with electronic locking feature (only available on LE 4Runner)
Air springs (rear)
Computer controlled Adaptive Variable Suspension (AVS)
KDSS (standard on all models)
Michelin tires
Integrated front and rear mudguards
Three-coat paint with scratch resistant anti-acid rain clear coat
Integrated illuminated running boards w/ground lighting and Lexus “L” emblem on the scuff plates
Rain-sensing, variable intermittent front windshield wipers w/deicer
Water repellent front doors and windshield glass
Heated, tilt-down in reverse, electrochromic self-dimming outer mirrors with
power auto retract
Roof-mounted shark fin and glass antenna
Auburn Bubinga (real) wood trim on doors, dash, steering wheel, shift knob, above glove box, and on center console
Semi-aniline leather trim with perforated diamond-cut pattern w/contrast stitching
10-way power front seats (with power lumbar)
Heated and ventilated front seats
Rear heat and air conditioning (3 zone auto climate control)
Lexus Memory System for seats, mirrors, steering wheel, climate control and radio setting (system is linked to each FOB for separate user settings)
Second-row heated seats with 40/20/40 split, fold, recline, fore and aft slide adjustment, 60:40 walk-in
Third-row seats with 50/50 split and power fold flat, flush-with-floor (buttons to operate located in the cargo area and by the passenger side second-row seats)
Auto-dimming electrochromic rearview mirror w/compass
Auto leveling HID headlamps with Adaptive Front Lighting system w/headlight washers
Electric fuel lid door release
Front and rear door courtesy lights, glove box light, dome light, front map lights, LED front and rear seat footwell, LED door handle well, shift lever and LED console illumination, rear reading lamps.
Reading lamps in 2nd and 3rd row
LED tail lights
Lexus Personalized Settings (LPS) set from nav system.
Two speed, auto up/down (all) power windows (slows just before closing)
Power tilt-and-telescopic steering wheel column with automatic tilt away, for easy egress.
Steering wheel–mounted cruise control switches; audio controls; camera controls; multi-systems toggle switch and voice command button for navigation
Tonneau cover
Brake override system
Auto leveling rear air suspension
Rear Seat Entertainment System includes remote control and holder
Intuitive Park Assist
8” HDD Navigation; Lexus Enform® Destination Assist, and eDestination; Lexus Insider™; voice command casual-speech voice recognition system; XM NavTraffic® and NavWeather™; XM Sports and Stocks;
Mark Levinson® Surround Audio with 17 speakers,330 watts of power, all channels driven, @ less than 0.1 percent Total Harmonic Distortion (THD), 20-20kHz and DVD/CD changer
Wide-view monitor system - Front, Rear and Side Camera
Pre-Collision System
Dynamic Radar Cruise Control w/Crawl Control
Driver Attention Camera system
Lane Departure Alert
Intelligent high-beams
Koz
dont know, thats why i asked. whats the frame number?
all the xtra stuff as pointed out in koz post is well worth the 15-20 grand more than the 4runner (lets not forget the v8!)
No need to know...go look UNDERNEATH a TLC and your GX...BIG differences in the way the crossmembers are arranged! GX (and 4runner) underbody leaves a lot to be desired. :(
Koz, but can your GX park itself?!! Ha, i beat you on one thing!! :D
Even at the price of the GX there are still some things that are missing, like roof cross rails, skid plates, tow hitch and HD radio. You have to get the Premium model to get HID, side molding and even a cargo cover!
Koz
Koz
Yeah, but you have the quiet comfy ride with the Mark Levinson system...my future goal is to own a Lexus LS460 with Mark Levinson Reference system....
The Levinson doesn't even get mentioned anymore and yet it is still the best OEM system on the market. I haven't heard anything better then the one in the LS and the GX is very close. I can run either one of the systems (IS/GX) at full volume and there no distortion at all. It seems, the louder you run it the better it sounds (not that it doesn't great at low volume). I can listen to music I've listened to all my life and hear things I've never heard before.
Koz
Koz
That is because every luxury brand now has their signature high-end audio system! I think that the Acura ELS system is probably 2nd best. Jaguar B&O system is pretty good also. But, only a few of them arrange their speakers appropriately like the Mark Levinson system, esp. the Reference system.
Hey Koz,
For the differences you quoted, is that the Premium GX?
I don't like how Lexus has started to put a trim line within a model... noticed the GX and CT are setup this way. It's almost Honda style, to have a certain feature or option, you have to move up to the next trim and then also get stuck with things you don't want.
Hey Koz,
Those differences are between the 4Runner and GX.
As fas as the Premium model, almost every vehicle built has different trim levels. Look at the 4Runner, SR5 - Sport - Trail - Limited!
Koz
Lexus -> Toyota
I have a Lexus GS sedan and recently purchased a 2007 4runner.
My only complaint (so far) about the 4runner is that I can hear some "door rattle" when I turn up the volume on any tracks with decent bass (JBL Stereo)...whereas the stereo in the Lexus is damn tight.
Not sure if this is "to be expected" or if I should try to resolve. I can tell that it is not the speakers themselves Any one else have this issue?
Lexus has more insulation in the doors?? Thus, most Lexus doors have more "weight" to them when you open/close them.
Kaliram
