belt retractor
gomoboo
06 4 Runner right rear seat belt is hung up. I plan on taking the panel that surrounds the belt guide off. I can see that the belt is twisted in the guide. I want to remove the panel just enough to access the guide. I see a little access panel by the guide. I was going to remove it, assuming there is a bolt under it. Is it safe to remove this access panel, or is it some sort of airbag panel? I don't think it has anything to do with airbag, but, I used to work on jet aircraft, and I don't touch anything until I know what it does. Appreciate any info. Thanks.......
Had a felocity I use to have when younger, "when in doubt, whip it out".
I opened mine up, but, enough to reach in there to add some washers and nuts to a fire extinguisher holder. Like when working on the front bumper area, (air bag sensor) in that location, just disconnect power to the battery.
I opened mine up, but, enough to reach in there to add some washers and nuts to a fire extinguisher holder. Like when working on the front bumper area, (air bag sensor) in that location, just disconnect power to the battery.[/QUOTE]
So, is the little access panel up by the belt guide just a cover for a bolt?
Yes,I do believe so. I haven't checked, but, do believe the air bag assm is in there also.
The other little pop out panels in the back also for bolts. Probably pull the trim/seal strip out by the door and you should be able to get enough room to debolt and pull out enough to play with it. I think there was also some push in clip holders inside the panel.
Just disconnect the + power on battery and it will remove power to the system to play w/o setting it off.
