I got the tray organizer one from Amazon today like $15 tray looks good and fits fine. It says made in china but nice quality.
Don't have my '18 yet. Shopping for mobile ham radios and want to see if somehow could take a measurement of the lower center dash pocket, the wider one below the usb and power outlet.
How wide and tall is the opening? Thanks!
Approx 6 1/4" x 1 3/4" at the mouth, but be advised, the pocket "tapers" to a smaller area as it goes back.
Thanks MeefZah!
i have an Icon IC-2730 (incidentally used to be Meefzah's)
I definitely can't complain. Ended up just crimping a new connector onto the existing cable and it's worked perfectly. If you don't need bells and whistles it's a fantastic radio. Only thing I need is a good way to mount the mic clip to the center tunnel without drilling rivet holes (open to suggestions). I'd like to have that cupholder back eventually haha
your 2730 should have come with an adhesive mic mount
Having seen how large most radio bodies are, I would agree not to try to cram a whole radio in there on account of lots of needed trimming and heat buildup concerns. Mount the unit under your seat (or similar out-of-the-way location) with a speaker or two and you'll be much happier.
i have an Icon IC-2730 (incidentally used to be Meefzah's), and the faceplate fits perfectly with just a press-fit into that opening and stays put. It doesn't sound super robust, but it never moves unless I want it to. It also blends in really well with the rest of the dash. No trimming needed unless you really want to hide the faceplate cable (you can see it in the photo)
From my driver seat, the only thing I can't see easily is which channel is active, but it's rarely a problem (I've only accidentally spammed the WIN system with casual simplex banter once...). I overall love the radio if you just need a solid dual bander for comms and not all of the extra bits and bobs coming on flaghsip mobile rigs.
Ha! I wondered if you ever bought the cable and installed that thing. Hope it is working out well for you. I made it about 2 months before I bought another IC-2730, LOL... what a great unit... serves as my HAM, wx center, FD radio, and scanner...
Drill baby, drill!
Seriously, holes are insignificant - if you remove the item later, plug them with black nylon hole plugs and it looks just fine. Last vehicle I traded in was my Taco, and I plugged the visible holes with hole plugs... actually used electrical tape over a couple that were in blank switch panels... dealer didn't even notice when he took possession of the truck.
If you don't remove the item, then it's a non-issue, because the holes allow you to use it correctly and reclaim your cup holder.
Guys, this model looks to be all the radio I need...for now. Ha!
Questions for you though:
I looked up the model: IC-2730 and Icom kept bringing up a model with an "a" at the end. Is this an update to your models or are you just "short-handing" the model you have now?
I am seeing pictures of the mic plugged into the faceplate and the radio unit's "brains". Are both an option or just one?
Last, [MENTION=143747]Bryguy17[/MENTION], how is the radio visibility with a water bottle or cup in the front cup holder?
What radio is this? Thanks!Much better. Going to continue to fixate on improving the functionality of this area.
I dont dip but has anyboody come up with something else to do with this small opening next to the USB input?
